Help with Sway Bar Bushing Kit
I noticed that one of the link bushings in the Sway Bar was worn so I decided to replace it. The kit is from Advance Auto Parts (poly).
I replaced the link bushing with two halves and a metal cylinder in the center (looks like the original except orginial was one piece rubber grommet.
But after that i was left with some parts in the kit (a solid grommet with smaller diameter hole and each kit had one nut and two different washers).
Seemed like an odd combo for a kit.
Oh the form Sway bar Bushing mounts are seized. I have used PB Blaster but any tips using a blow torch to loosen the nut.
Thanks
You guys rock
Each kit is left and right as above.<!-- END FULL SIZE ITEM DETAIL PIC -->
