can't get tranny back in!!
Old May 28, 2005 | 04:44 PM
green52's Avatar
green52
ok, i put in new clutch in my 76 f150, and i've been trying for 2 days to get the t-18 tranny back in. i can it about an inch from the bellhousing and that all the farther it will go. i've tried putting in guide studs in to make sure it's lined up, i've tried turning on the tailshaft to see if i can the splines to line up. am i missing something?
Old May 28, 2005 | 04:47 PM
brokebronco's Avatar
brokebronco
Did you use the special tool to line the clutch disc up properly? Sounds like the input shaft isn't going into the pilot bearing.
Chris
Old May 28, 2005 | 05:24 PM
green52's Avatar
green52
yep i used the tool, i can put that in and out with no problem. how crical does the angle of the tranny make to getting it lined up?
Old May 28, 2005 | 06:40 PM
holland501's Avatar
holland501
The disc needs to be centered almost perfect. Now let me ask you a couple of questions. Are you using a transmission jack or are you trying to muscle it back in? If you have been working on this for 2days without a trans jack, you may have another problem. I have had this problem myself. You are under the truck, straining and grunting but you can't get it in the last inch or so. Your arms are about to fall off so you let the trans hang for a few minutes. When you finally do get everything buttoned up and take that test drive, your new clutch Chatters! What has happened is, the center hub of the disc has been bent from supporting the weight of the transmission. At this point you might want to unbolt the clutch assembly and check the disc for run-out. This is just a heads-up to potential problems. Good luck.
Old May 29, 2005 | 01:00 PM
TerryK's Avatar
TerryK
I had a similar frustration a few years ago. Turned out that the clutch disk from the parts house was incorrect spline count for my tranny (Apparently mis-packaged).
It took me 2 days of fighting it before I took it apart again and attempted to slide the disk onto the input shaft.
Terry
Old May 30, 2005 | 08:08 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Terry, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
