wireing problem
Old Feb 9, 2000 | 05:03 PM
EagleFly's Avatar
EagleFly
wireing problem
Hi, I have put a 1987 351W into a 1992 F-250. My problem is, the plugs on the distibutor are different, the 1992 wiring harness is round but the 1987 distributer plug is flat. Does anyone have a diagram showing how I can wire these two togeather to get my engin to run?
Old Feb 9, 2000 | 08:31 PM
Phillip Guidry's Avatar
Phillip Guidry
wireing problem
If you swapped 351 for 351, reuse the original dist. Also, you should've reused the original injectors as well.I would guess that the colors don't even match up as well?
Phillip
Old Feb 9, 2000 | 11:06 PM
Nate_64's Avatar
Nate_64
wireing problem
Old Feb 10, 2000 | 12:04 PM
Trew's Avatar
Trew
wireing problem
The problem that you are encountering is due to the fact that the your existing wiring harness incorporates a "Closed bowl distributor". This means that the TFI module is remotely mounted (ie. on the fender skirt). The older ('87) distributor has a the TFI module mounted on it's body and plugs directly into the Hall Effect Sensor, which is in the distributor bowl. Since these engines have different wiring harnesses, your easiest fix is to re-install the distributor from the '92 or, if it's gone, buy another one from a wrecker/supplier. If you get into harness splicing when it's not really needed, you're begging for problems down the road.
Old Feb 10, 2000 | 01:15 PM
Phillip Guidry
wireing problem
Wow ! That was a good & quick response Trew ! Keep it up dude,we can use you more often around here.
lol,
phillip
