Found something in transmission pan?
Old May 27, 2005 | 07:20 PM
FastruckDriver's Avatar
FastruckDriver
Ok, I know this sounds wierd. Just bought a 1990 F-15 with the Automatic AOD transmission. 4x4 5.0. I was changing the transmission filter and after I drained what fluid was left in the pan I found something that looks like a Jewish dreidel only round. It is plastic, round at the bottom, with a gasket around the "round" part, out of the top is a round shaft or pin that is about 1 inch long.
Again, it was laying in the bottom of the transmission pan......
What is it and where does it go?
Old May 27, 2005 | 08:01 PM
Hooker Bob's Avatar
Hooker Bob
This is a plug to keep dirt from entering the pan thru the hole where your dipstick tube goes. It is used until the trans is installed at the auto plant assemblers just poke them into the pan when installing the tube. it doesn't hurt anything and you can discard it and rest easy.
Pat
Old May 27, 2005 | 08:27 PM
FastruckDriver
Thanks Pat!!!
This forum is great....
I wish the original owner had changed the fluid sooner than 140K though
antirice
Feb 28, 2011 06:30 PM
Fordenthusiasts
Nov 8, 2010 09:43 PM
Ron79fordguy
Nov 6, 2007 06:18 AM
labarnas
Apr 23, 2004 07:38 PM
