Throttle Cable
Old May 27, 2005 | 04:03 PM
66beater's Avatar
66beater
Throttle Cable
What kind of throttle linkage is my 66 suppose to have? I have a cable running to the autolite 2bbl on a 352. the cable seems long, but basicly looks stock. I can't find a listing for a cable, though. everything I have seen listed is hard linkage for this year.
Old May 27, 2005 | 07:28 PM
Putt's Avatar
Putt
Your '66 should use a cable type throttle linkage. That is stock as far as I know. Seems like the hard linkage appeared in the early to mid '70's?
Old May 27, 2005 | 07:55 PM
66beater's Avatar
66beater
So where do I find one? the parts shops around here don't even have a listing for it.
Old May 27, 2005 | 08:48 PM
jav409's Avatar
jav409
Boy funny you should mention this, i ran into the same problem, my local ford dealer located one somewhere back east for like 68.00 ,i needed it now not then and thats a lot of gas money , my solutuion, I went to a local bassboat dealer and ordered a minnkota Maxum 74 foot control cable ( their are 2 but you only need one ) I took the cable and cut it in two ( both ends have a ball on them) I then removed the cables from their housings, and, took the insides out of the old cable ( mounted on the firewall ) I went to the local autoparts store and under the "Help" Section found a box of differant sized cable fasteners ( round ones with screews going into them and a hole drilled to put the cable tru.), I also took a stainless steel bolt 1/4 20 and driled a hole in it just big enough for the cable to go tru. I mounted the bolt to the foot throttle bar using the threaded side of the bolt and a nylock nut. ( I also cut the head off the bolt to make it a post. Then I ran my new cable tru the bolt into the original cable housing and out to the carb. I removed the old fastener from the throttle arm and installed the new fastner using a screw that was just long enough to reach the center hole and added blue locktight to it then I simply pulled the cable and tightened the outside screew on the fastner, It works like a charm and I'v had it on for 4 months wth no problems, I have a spare in the glove box if I need it but so far no problems, BTW it feels way smoother than the original.
you can get all this stuff for about 25.00.
Old May 27, 2005 | 08:52 PM
frosty64's Avatar
frosty64
You canget the new cable from LMC if you can't find it local.
Old May 27, 2005 | 08:57 PM
barry's Avatar
barry
According to my 64-72 Ford parts books, your truck with a 352 should have hard linkage. 65-66 were like this. The 240-300 6 cyl. had a cable. What is your serial number? Post it to see what the truck is supposed to have for an engine. Maybe a 352 was substituted for a 6 cyl.
Barry
68torino's Avatar
68torino
fordbeast_80 has an interesting setup he used in his '70 F250. Check his gallery might work for you.
Old May 27, 2005 | 10:54 PM
hiball3985's Avatar
hiball3985
I have a completely stock 66F250, 352 with cable
Old May 28, 2005 | 10:28 AM
Putt's Avatar
Putt
barry, that is strange. My '66 F100 no longer has any stock engine parts but I purchased from a Ford dealer a replacement cable for the stock 352 application about 15 years ago. I do not remember having to explain or give any additional info to get the cable. The cable is/was part number C5TZ-9A758-AH, I wonder what gives??
Old May 28, 2005 | 11:51 AM
66beater's Avatar
66beater
I don't have my number here, but I posted my serial number before, and 2 people responded, one saying it wasn't a ford number, the other saying it was but for a deisel. I am pretty sure my truck was pieced together. It looks clean, but I think it might have been wrecked hard and peiced back together.
So the 6 cylinder had a cable?
Old May 28, 2005 | 05:23 PM
uba40's Avatar
uba40
Talking Bicycle Brake Cables Work
Hi,
When mine broke, I went to the local bicycle shop. Bought a brake cable, massaged and carved the little lead piece on one end, then replaced the whole doggone cable.
Was more pain than effort.
Total cost............ Less than $5.00
Enjoy.
uba40
Old May 28, 2005 | 08:03 PM
MR Harley's Avatar
MR Harley
66beater, look in my gallery, i took 2 photos. The one on the truck is one i made. The one on the breather is stock. I used a stock throttle cable 20".
Old May 28, 2005 | 08:55 PM
barry's Avatar
barry
PUtt, You're right. It's buried in the text, between all the 6 cyl listings. C5TZ-AH. I should have remembered back in the day, we carried C5TZ 9A758-AG and AH. AG was the 240-300 cable and AH was the V8. It's the 4x4's that are supposed to have mechanical linkage. Egg on my face!!
Barry
Old May 28, 2005 | 09:39 PM
Putt's Avatar
Putt
Hey, barry thats alright. Goodness knows I've done that more than a few times. Worked in a jobber store for 8-9 years. I wonder if that cable is still available?
Old May 29, 2005 | 04:53 AM
jowilker's Avatar
jowilker
66 Check (Motorhaven) (Parts Shop button at the top) we need to support the site first when we can. I know Carolina Classics carries them, one of out locals bought one from him not too far back.
John
