Please help testing A/C Clutch Cycling Switch
Old May 27, 2005 | 02:31 PM
demarpaint's Avatar
demarpaint
Hi and thanks in advance,
How would I test (if Possible) the A/C Clutch Cycling Pressure Switch on my 88 E-150 4.9L? I had to replace the evaporator, it was leaking along a seam. I have a feeling the Cycling Switch is bad too.
I was hoping for a simple test w/o Gauges. The Switch is in a real tough spot to remove it. I also heard they could be adjusted. Any info would be greatly appreciated. There are no leaks in the system and no blockages, that we detected when we evacuated and recharged the system.
Thanks again,
Frank D
Old May 29, 2005 | 09:06 AM
demarpaint's Avatar
demarpaint
I found out how to test the A/C Clutch Cycling Pressure Switch , long story short its not working.
At an idle with a fully charged system no leaks etc. I have approx 60lb back pressure, 125lb on the high side.
With engine running at cruising speed 44lb back pressure 225 high side.
At idle the A/C is warm at the cruise speed its blowing cold air.
The compressor is working properly at cruising speeds.
My question is: Could the in operative A/C Clutch Cycling Pressure Switch be causing the problem?
Thanks
Frank D
Old May 29, 2005 | 12:05 PM
demarpaint's Avatar
demarpaint
back to top
Old Jul 2, 2005 | 12:50 AM
greg_23805's Avatar
greg_23805
If the switch isn't working as you say and the compressor is running, then what you mean by the switch not working is that it won't cut out the compressor. How did you test that? You would have known when you charged the system back. Until you get enough freon in the system, the ac clutch will kick on and off because the pressure is low and then builds as the compressor is off.
If your compressor is always running, that is not why the air is warmer at idle. It is normal for the air to be warmer at idle because the suction/low pressure is quite a bit higher at idle then at cruising speed. The faster the compressor runs, the more suction it puts on the low side of the system and the lower the pressure goes. The lower the pressure, the colder the air.
If your charge is correct, the only thing you might check is that the condensor is clean and not clogged with bugs, radiator too. Also check the fan clutch. If it is not working right, it won't run faster when the temp gets high and the pressure will get high during idle.
Old Jul 2, 2005 | 04:52 AM
demarpaint's Avatar
demarpaint
Situation resolved:
When the evaporator was installed, no Orifice Tube was put in. After pulling out the remaining hair on my head I figured it out. Popped in an Orifice tube, and new accumulator and the A/C works like new!
I got an education in A/C for sure, and resolved to now do all auto repairs myself.
Thanks
Old Jun 16, 2010 | 01:50 PM
markford166's Avatar
markford166
where is the A/C cycling switch for a F350 diesel 1999 w/7.2
and/or what does it look like, where is it near ?
Old Jun 16, 2010 | 02:00 PM
projectSHO89's Avatar
projectSHO89
Start here: https://www.ford-trucks.com/forums/7...xpedition.html
Brooks Rowell
May 31, 2025 09:02 PM
Digging Dog
Jul 9, 2015 01:48 PM
ruffneck30
Feb 9, 2013 09:06 PM
1998Ranger25L153CID
Jun 18, 2007 11:00 PM
jims89bronco
Apr 13, 2004 01:30 AM
