Loosing tranny fluid
Old May 27, 2005 | 12:56 PM
corkybarder's Avatar
corkybarder
97 F350 Powerstroke A/T - Keep loosing transmission fluid, but I don't see any signs of leaks or spots on the drive. Does this transmission have a vaccuum modulator that could have gone bad and is sucking the fluid out? If so, where is it located. Are they hard to change?
Thanks in advance
Old May 27, 2005 | 01:55 PM
csramsey640's Avatar
csramsey640
No modulator valve. Is it 4wd? If so, pull the plug on your transfer case. if fluid comes rushing out, its the rear seal. also ck the torque converter hub seal area, your access pan is fairly easy to remove. any signs of oil, and you got it. Other than those two areas that can "hide" a leak, it has to be leaking externally, or at a cooler
sbrodacz
Mar 7, 2013 12:33 AM
Mdt1992
Aug 4, 2012 05:33 PM
jcstarr
Apr 30, 2007 10:10 AM
geraldweber
Jan 15, 2007 04:08 PM
bellville
Jan 29, 2002 09:18 PM
