Power Brake Problem
Old May 26, 2005 | 08:16 PM
sgoff's Avatar
sgoff
Cool Power Brake Problem
I am driving a 1971 Ford F250 with power brakes . When I step on the brakes I can hear a vaccum leak from down on the floor where the rod from the brake pedal is . Is there a way to stop this or does this mean the vaccum pot is bad ?
Thanks
Old May 26, 2005 | 11:47 PM
Rubiranch's Avatar
Rubiranch
The booster is bad. It is most likely the seal aroung the shaft inside by the diaphram.
Old May 27, 2005 | 01:18 AM
sgoff's Avatar
sgoff
Thank You , Will pull it off in the morning and get a New One .
Thanks Again
Old May 27, 2005 | 08:00 AM
Six Niner's Avatar
Six Niner
is it dangerous to drive one like this or just aggravation to listen to?
Old May 27, 2005 | 09:11 AM
jor's Avatar
jor
It's dangerous. I replace the carb on my 67 a few years ago and the new carb did not have a vacuum port on the back for the PCV. I cut my brake booster vacuum line (intake to booster), installed a "Y" and hooked in my PCV. This changed the vacuum to the booster and the brakes were almost non-powered. It was difficult to stop like that and with a load, I could not make and emergency stop. Bad idea to drive this way.
jor
Old May 28, 2005 | 12:21 PM
rebocardo's Avatar
rebocardo
Dangerous idea because when it suddenly fails, you will find it almost impossible to get enough leverage to lock the brakes up, especially with a load. Mine blew a leak and still with part of it working it was a tough stop with a load of wood.
I believe the main difference between manual and power brakes is the angle and pivot action of the pedal that allows you to apply more pressure and a longer travel.
FWIW: I put a F-350 master cyl/booster combo, for disc brakes, on my F-100 from Advance Auto for <$100 (I have four wheel drums). It works great. I am sure it will be bolt in for a F-250, same as my F-100. It comes with adapters if you want to eliminate the Ford adapters and just use reg. 3/16 line connectors.
