Cam Sensor Problem
Old May 26, 2005 | 05:18 PM
45th mss's Avatar
45th mss
Cool Cam Sensor Problem
I have a 97 F-250. I was replacing the cam sensor and broke it off. Any ideas on how to get the rest of it out of the block????????
Old May 26, 2005 | 05:22 PM
trike1946's Avatar
trike1946
Bummer! Nothing sticking out at all? What do you see when you look at it? Any way to get an easy out into it?
Old May 26, 2005 | 05:27 PM
45th mss's Avatar
45th mss
I think that is the only idea. Just not a lot of room. Thought maybe someone knew a magical way!
Old May 26, 2005 | 07:29 PM
trike1946's Avatar
trike1946
Take your time. Walk away if you have to and come back to it later. It will be a pain but it can be done. Maybe someone else will come along with better info. Good luck with it.
By the way - Welcome to FTE.
Old May 26, 2005 | 07:37 PM
Kwikkordead's Avatar
Kwikkordead
Drill a hole in the CPS, try not to go all the way through. Screw a wood screw into the hole and use the screw to pull the rest of it out.
Old May 27, 2005 | 03:08 AM
fedextech's Avatar
fedextech
kwik's idea is a good one. i've never run across this before...i'm not sure how much of the sensor you have left. i'm concerned that if it's a small amount and you press on it with a drill ( tight fit even with a right angle drill ) it could push it on in to the timing cover and into the engine. i would try this first, clean the area on the sensor real good with brake shoe cleaner, attach a bolt to the sensor with some super-bond adhesive. put the head of the bolt to the sensor. once it's cured put a flat washer and 2 nuts on the bolt, jam the nuts together. this will allow you to turn the sensor and apply pressure under the washer with a prybar get it out. kwik's would be faster if you knew for sure the sensor would not fall into the engine and if you have access to a right angle drill. have a good day !
