electronic speedometer
Old Feb 17, 2000 | 07:39 AM
carl_1's Avatar
carl_1
I found an archived post on this subject, but a solution was not posted. Can anyone help?
I have a 93 f150 4x4 that no longer has the 8.8 rear and speed sensor (switched to a 9" after bending the 8.8 housing)and I would like to have a working electric speedometer.
I heard that ford used a cable from the 1356 transfercase to a converter under the dash to make electonic speedos work on some 92 and up trucks. Does anyone have this system in their truck? All the trucks I have seen use a speed sensor pick-up from the rear axle housing.
Thanks
carl
Old Feb 17, 2000 | 11:49 AM
PAUL_2's Avatar
PAUL_2
Carl ,
I know adapters are used on Gm vehicles that have larger tires installed to correct the speedometer . Im pretty sure any shop that deals in 4x4 alterations can tell you for sure what you will need for your truck . Does your transfer case have the hole where the speedo cable would go ? Plus the output shaft on the T case has to have the gear on it that turns the speedo gear . Sorry I cant be of more help .
Paul
Old Feb 17, 2000 | 09:12 PM
Mtruck96's Avatar
Mtruck96
dstanford
22
Oct 14, 2011 08:45 PM
Ronin007
New York Chapter
15
Oct 8, 2007 07:59 PM
n003lb
Kansas Chapter
Mar 30, 2007 09:01 AM
MustangGT221
Nov 1, 2004 06:43 PM
