bigger tires
Old May 25, 2005 | 04:59 PM
glennhand's Avatar
glennhand
bigger tires
I have a 04 SCREW 4x2 thinking about putting on a leveling kit and bigger tires just wondering what I would have to do about the speedometer. Will it need to be adjusted or what. Also would this effect the MPG or what.
Old May 25, 2005 | 10:50 PM
transam396's Avatar
transam396
are you planning on lifting the front or lowering the rear ? and are you planning on keeping the stock rims and if so what size rims are they, if not what size rims will you be running
Old May 26, 2005 | 10:02 AM
glennhand's Avatar
glennhand
I will be raising front end. I will be keeping the stock 17" rims. I'm in Afghanistan right now and plan on doing this when I get back to the states in about a month.
Old May 26, 2005 | 10:22 AM
transam396's Avatar
transam396
good deal . I assume since you are i Afghanistan then you are military . so let me start with a good job and be careful . Ex NAVY here. there are several different companies that make the leveling kits for these trucks most of the guys on here say that with the 2 in lift you can put a 305/70/17 on there(I think thats the right size) same size that comes on the H2's matter of fact read where one guy bought his tires from the hummer dealership for somethin like 100 bucks each, do a search on here and yo will find quite a few threads where ppl are talking about the various leveling kits and there exp with them
Old May 26, 2005 | 11:20 AM
SkinsF150's Avatar
SkinsF150
Come Back To Us Safely
God bless you and all our troops, serving worldwide.
Old May 26, 2005 | 11:33 AM
glennhand's Avatar
glennhand
next question is I pull my boat a lot. Boat is quite heavy but with not much tongue weight at all. right now the truck pulls the boat very well with the bigger tires and the front lift will it effect my towing at all and also will the back sag lower then the front when towing, and how about the speedometer will it need to be adjusted.
Thanks for all the support for us guys over here it is appreciated.
