how much do injectors run and how hard are they to change? if anyone can help i would appreciate it. thanks
How much depends on what injectors you want. Mild to wild can run from ~$900 to upwards of $3500.
How hard is subjective, but there are very good tech articles as well as lots of experience here that can walk almost anyone through it. Plan on a full day for the installation if you aren't at least an accomplished shade tree mechanic. Takes about two to three hours for the experienced.
it took me around 4- 4 1/2 hours to change all 8. I am also intercooled so i had to remove and reinstall all of that too. If your stockers are bad it is cheaper to replace them with mild aftermarkets rather then oem rebuilds. if you are interested in a good aftermarket injector PM me.
Some places will rebuild yours for like $600, aftermarket ones will run closer to $1000, all still cheaper than the dealer. They aren't that hard to change, there are many threads here explaining how to do it.
