1978 - 1996 Big Bronco
NEED HELP with REAR WINDOW
Old May 25, 2005 | 12:53 PM
ericMCG's Avatar
ericMCG
Exclamation NEED HELP with REAR WINDOW
hi--
just got a 96 bronco and the rear window just quit working--in the down position. the inside switch doesn't work, nor does the key. it's definately not the fuse because the other power windows work fine. any ideas what to check? or why it would suddenly quit working? thanks!
eric
Old May 25, 2005 | 12:58 PM
greystreak92's Avatar
greystreak92
The power feed for the rear glass is in no way linked to the other two windows. Circuit breakers 12 and 14 are the TWO power feeds for the rear window motor. Since its not working at either location I doubt its either of the CB's anyway. Its more likely a stalled or dead motor or something blocking the glass itself or the regulator. Follow the RED LINK in my signature. There are at least two very thorough tailgate/rear window links listed in the Big Bronco FAQ's there.
Old May 25, 2005 | 03:52 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome ericMCG, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 25, 2005 | 09:29 PM
jem270's Avatar
jem270
Before you spend a lot of time (like I did) check and make sure the plastic bushings are on the “jambs” on both sides of the tailgate. They probably should be on the doors also. Mine were missing on both sides of the tailgate and missing on both doors. I wrapped them with electrical tape (to make the diameter bigger) and the tailgate window worked great. I also wrapped the doorjambs with electrical tape and they don’t rattle anymore. I already had removed the tailgate motor and tested it. I already cleaned the gears and the slides and relubed them. I discovered the fix by opening the tailgate and closing the latch (like the tailgate is closed) on the driver’s side manually. The window did not work but if I pushed harder on the latch then the window worked so I figured if I made the latch larger in diameter then it should work and it did. Just my experience. (I had previously hot-wired the motor so I knew it was good.) Important: make sure you open the manually closed latch before you close the tailgate or the tailgate will jam closed and be a bugger to reopen (I did it twice).
1988 Bronco - 302 - auto trans - manual hubs - 208,000 miles
