front end swap?
Old May 25, 2005 | 08:27 AM
wheelhoppin67's Avatar
wheelhoppin67
front end swap?
Im looking into buying a 78' with front disc power brakes to put under my 67' with no power and front drums. Are the front ends interchangable? and would i still have the same wheel spacing with the disc brake as i do with my drums, becauce im running aftermartket wheels and it would make a difference, thanks
Old May 25, 2005 | 09:07 AM
ranger240's Avatar
ranger240
here is a link to the article written up by Ken Payne, one of the greats on FTE!!
https://www.ford-trucks.com/article/...rd_Trucks.html
I hope this helps you out.
maybe we should consider putting this particular DIY as a sticky at the top of the forum, as it is by far the MOST asked question on this forum.
_Ken
Old May 26, 2005 | 05:53 AM
moparnut's Avatar
moparnut
Wheel hoppin 67.I just completed a 77 swap to my 67.Both 2 wheel drive trucks.You will have to swap out the I beams.The drum spindles are bolted up with 4 bolts .The disc spindles in thethe 77 are attatched directly to the king pins.King pins are a little bigger in the 77,so you wont be able to change at the king pins.Swap the I beams,change the proportioning valve,vacum canister and master cylinder.New banjo hoses ,rotars and calipers and your in business.Having the whole parts truck is the way to go. moparnut
Old May 26, 2005 | 06:29 AM
jowilker's Avatar
jowilker
yes, yes, & yes You are on the right track, continue on.
John
