a couple quick questions
Old May 24, 2005 | 10:48 PM
cgrandahl64's Avatar
cgrandahl64
93 f350 7.3 e40d
1. where is the vehicle speed sensor located? Does this control the speedometer? (I have a digital speedometer and odometer)
2. What is the sensor on the rearend? is this jsut for abs or is it also for vehicle speed
3. on the fipl, what are the colors of the wires?
4. are there any simple instructions for juimping the wire under the dash to get trouble codes?
thanks in advance.
Old May 25, 2005 | 08:05 AM
nogo73's Avatar
nogo73
1). on the transmission- yes ( I pulled the fuse once an drove around like this because some body bet my truck had a computer -unless its has a E40D it doesn't)
2). just for abs
3). ? fipl ?
4). I had a stick never seen anything under the dash.
Old May 25, 2005 | 08:22 AM
PLC7.3's Avatar
PLC7.3
#1...on the rear axle pumkin.
#2...RABs and speedo
#3...BR/W...GY/W...GY/R
Was told how but I have CRS....can't remember s..t. If I have time I will try to find out and write it down this time..good answer.
