1978 - 1996 Big Bronco
getting a 44 code
Old May 24, 2005 | 09:38 PM
bgblktruk's Avatar
bgblktruk
Question getting a 44 code
Hey guys I recently tuned my truck up (88 w 302) and I had been getting a 44 code. I replaced the O2 sensor and reset the codes and I am still getting the code. I haven't tested the wires to the sensor yet (I've been pretty sick the last few weeks). I'm thinking of heading down to San Diego this weekend for a bachelor party but I'm getting about 9 mpg. That will be an expensive trip for me. I was hoping there might be some ideas out there.
Thanks
Mike
Old May 25, 2005 | 12:10 PM
greystreak92's Avatar
greystreak92
Code 44 indicates a non-functioning Thermactor system. Check your smog pump, air injection hoses and the check valves connected to them. Double check the vacuum lines AND hoses running to/through the diverter valve as well. On the outisde chance that all is well with these components, the TAB and TAD solenoids are the "last resort" problem children. Check the wiring to them and finally check that they are both functioning properly. (The process for checking them is rather tedious so I would recommend checking all the other things first). The EGR should have no bearing on the functionality of this system.
Old Aug 27, 2005 | 02:29 PM
bgblktruk's Avatar
bgblktruk
Opps it was actually 41
Hey guys I was just looking through my notes and it turns out it was a 41 not a 44. I'm not sure if that was just a type o or I'm losing it. Being that I'm not even 30 yet I hope I'm not losing it, although I am mostly grey at this point.
Thanks
mike
Old Sep 6, 2005 | 12:24 AM
greystreak92
Code 41 is a lower-than-normal voltage response from the O2 sensor during the last 40 operations of the engine. Most likely a dead O2 sensor.
Buetra19
S. California Chapter
Aug 2, 2013 11:58 AM
Buetra19
Aug 1, 2013 12:40 PM
DRH 69
Jul 2, 2012 05:35 PM
tip49
Jul 9, 2009 10:27 PM
Agapemou
Sep 10, 2003 03:28 PM
