Starter Shorted
Old May 24, 2005 | 10:39 AM
1985 Quadravan's Avatar
1985 Quadravan
Starter Shorted
My van had probelms starting. Solenoid would click on and off like a machine gun when you turned the key over. New solinoid didn't fix the problem. Pulled the starter and tested it with voltmeter, it was shorted. Bought a rebuit one and it worked great until last week. Same problem.
Why is this happening? Only commonality I see is that the battery died after I left the ignition in the on position prior to both failures.
Old May 24, 2005 | 01:40 PM
rlmdad's Avatar
rlmdad
I assume that you're referring to the starter relay and not the starter solenoid. Starter relay is up near the battery, starter solenoid is part of starter.
Usually when the starter relay clicks on and off like that it's due to low battery amperage. I'd check the battery for a bad cell. Leaving the ignition in the "Run" position will after a considerable time pull down the battery (unless you also leave the headlights on) because you have several things that have power all the time, i.e. the EEC module keep alive memory circuit, the radio's presets, etc. But they pull little amperage and I think it would take a while to pull a good battery down that far.
Just my 2 cents.
Ron
Old May 24, 2005 | 05:39 PM
Franklin2's Avatar
Franklin2
Turn the headlights on, and then try to start the truck. If the headlights go completely out, then you have a battery problem or a bad connection at the battery or the ground at the engine block.
If the headlights stay bright, but the truck won't start, I would suspect the new starter, or the connection at the new starter.
bchez
2004 - 2008 F150
Jul 27, 2012 10:53 AM
wareagle0823
Jul 17, 2010 02:40 PM
Kijutsu
1983 - 2012 Ranger & B-Series
Sep 22, 2009 04:11 PM
Shorts
Nov 19, 2003 10:26 PM
