1978 - 1996 Big Bronco
Header or not to Header?
Old May 26, 2005 | 01:34 AM
94F150-408's Avatar
94F150-408
Yeah, you only need the crossover Y if your running single exhaust. If your running true dual, I would look into some good long tube headers as they are worth more HP than the shorties. I would have duals if it werent for the smog laws.
Old May 26, 2005 | 02:40 AM
greystreak92's Avatar
greystreak92
The Bassani setup produces very good HP from a 3" single tube. Not to mention the fact that routing true duals under a Bronco, while not impossible, can be a royal PITA. The "crossover" in the Y-pipe is the "icing on the cake" with this setup. The equal length headers keep the exhaust from each cylinder lined up roght behind each other whic enables a free-flowing constant "push" the the flow of exhaust gasses however, when the gasses reach the junction at the Y-pipe, since a V8 has two cylinders on each stroke, there is the possibility that the exhaust from one bank of cylinders could "run into" exhaust from the other bank. To alleviate the back-pressure and possibility of this, Bassani puts a small crossover tube between the arms of the Y-pipe so that IF this occurs, the gasses have an "escape route" and don't get bottled up or slow down when they hit the junction of the two "arms" of the Y-pipe. So it (the crossover tube) performs the same function that it would in a "true dual" setup.
Old Jun 17, 2005 | 12:31 AM
Fordbyford's Avatar
Fordbyford
I had bought a pair of Flowtechs for my 351 and a K&N Air intake Headers are equal leght powder coated They bolt up straight to my exhaust wich is also good if your looking to replace the exhaust system I think I got them at a good price Although its just a real bitch to get the bolts the give you on the insides of the pipe.
