I was jus wandering wat a ranger with a 3 inch body lift lift and 31x10.50s mud tires would look like...I checked the fitment guide and it says i can put 32x11.50s with the lift but i really dont feel like buying new wheels and was wandering if that one inch and all would really make a differance or if it will jus look fine wit the 31s. Thanks
what year Ranger? early body style 84-90 have a fender rub issue with 31's..91-current has more fender room and 31's should be fine without a lift. You can stick a 32 or 33 on your current rim as long as you dont go wider then 10.50. Check out www.screwtheboss.com i have a 86 BroncoII..but if yours is that year body Ranger then that's what it would look like with 3 inch body and 4 inch suspension sitting on 35x12.50x15 BFG Mud Terrains.
33X10.50 will need a body lift...the only problem i see is possible rubbing on the Radius arms when turning the wheell all the way in either direction completely..if that is a problem just buy wheel spacers that go on behind the rim.
