Front fuel tank
Old May 23, 2005 | 01:46 PM
Padre's Avatar
Padre
Question Front fuel tank
I just bought a '95 F150. Beautiful truck. Low miles. 4.9 6cyl. Manual. Dual tanks. I think the front tank's pump is out. I checked the relays and I believe all are good. I want to change the fuel pump but don't know if I have the 18 or 17 gal tank. Is there a way to tell the difference between tanks or will I just have to drop the tank and remove the pump to take to the parts store for comparison? Is the front/rear switch more likely the culprit? Thanks. I appreciate all the help I can get.
Old May 23, 2005 | 04:25 PM
winddance's Avatar
winddance
Check a manual for your make, model, engine and year truck. Or ask on this site if you don't have one and give all the details. I looked after I was done and my manual said 19 gallons (should have done that first, dah!) Here is the story on my 1991. First, the dual switch was bad. I took it apart and cleaned it and the pump started making noise. Problem is it was dry for so long that the pump went bad (or, the pump was bad so the switch got bad from lack of use). It cost me $35 to get a pump from a junk yard. I had the same question as you. So, spur of the moment, I just got a pump for the 16 gallon tank. Of course, it turned out that mine was the 19 gallon (long and narrow under the truck). I disconnected the spout and cut the tank straps with a sawzall because the bolts were so rusted. Then dropped the tank. Put the new pump in. Put new straps and bolts on. Works fine now. Except the gas gauge stays on 5/5 of a tank from 5/8 to empty. Oh well. I think it was a very easy job.
Old May 23, 2005 | 06:10 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Padre, to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 23, 2005 | 06:33 PM
tex94F250's Avatar
tex94F250
Long wheelbase or short? Most front tanks with the dual setup were 19 gallon from what I've seen.
Old May 23, 2005 | 09:37 PM
Popa Tim's Avatar
Popa Tim
Std cab would be 19 gal,
Supercab is 16gal.
I beleive all rear tanks were 18g
Cherers,
Popa Tim
Old May 23, 2005 | 10:16 PM
Padre's Avatar
Padre
Tanks (get it) every one for your replies. I have the std cab w/ long bed. I am going to monkey with it a bit before I spend the money for a new pump. Just as a test, can I switch the connectors on the switch and put the front wire on the rear switch post and vice versa or will that not make a difference? Is it possible the inertia switch needs to be reset or is there only one switch for both tanks? I need a service manual bad. Thanks again.
