Hello,
I need some help here. I have a 460 and on the back side of the heads, there is a hole.....This hole connects to the exhaust ports somehow. I know because when I welded up the exhaust, some of the smoke came out of that hole. SO.......My question is this, What is it for? and will it hurt if I plug it off? I assume it is for emmisions of some sort.
if you don't have or want the AIR pump you can put a soft plug (small freeze plug) in the hole to plug it, or if it happens to be threaded you can swrew a bolt into it, and cut the head off will do the same thing.
Thanks guys! I appreciate it....I'll have to put in some soft plugs....I just wish I had seen the holes before I put the motor in....It would have been so much easier
Oh well, I needed to pull it back out anyway...Day job. Guess I'll be busy next weekend.
