97 4.6 code P0401
Old May 22, 2005 | 08:14 PM
HillbillyTim's Avatar
HillbillyTim
97 4.6 code P0401
My 1997 4.6 check engine light came on 2 months ago. I checked the code and it was a P0401. I replaced the EGR valve and cleared the code. This week the engine light came on again and I pulled the same P0401 code. I replaced the DPFE sensor. One day later the check engine light is back on. Any ideas what I can try next?
Tim
Old May 23, 2005 | 04:40 PM
l-m tech's Avatar
l-m tech
sounds like the egr passage is stopped up.remove the trottle body adapter and clean it out.if you have high miles its more than likley stpped up.
Old May 23, 2005 | 06:01 PM
LxMan1's Avatar
LxMan1
Welcome to the forum
Old May 29, 2005 | 09:07 AM
50th ann's Avatar
50th ann
P0401
There are several reasons this code can appear. I just fixed my 98 F150 4.6 L 112,000 Miles with the same code. It turned out to be the EGR Ports were clogged with carbon. Disconnect the vacuum hose from the ERG Valve and cap it. Then apply vacuum (outside source) to the ERG while the engine is idling. If it continues to run smoothly the ports are blocked. The engine should stumble or stall if the ports are clear. To clean them you will have to remove the throat from the manifold. The EGR Valve or the PDFE Switch could also be the problem.
