borg warner 1356 Transfer
Old May 22, 2005 | 05:17 PM
jasonw302's Avatar
jasonw302
Hi all. I have a 1992 F150 with the E4OD trans and a BW 1356 mechanical transfer. I am wanting to change out the troblesome E4OD for either a C6, AOD or I would really prefer a 5 speed. My question is what can i bolt up to my existing transfer case. Any help will be greatly appriceated. Thanks!!
Old May 22, 2005 | 07:57 PM
oldhalftons's Avatar
oldhalftons
I know you can get stock transfer case adaptors for the C6, NP435 and T18/T19
It has the same pattern as a BW1345 and with a little dremel work it has the same pattern as a NP208. So its possible to swap in pretty much anything ford put in a 80's-early90's fullsize 4x4
