1978 - 1996 Big Bronco
power steering
Old May 21, 2005 | 05:21 PM
sprayed's Avatar
sprayed
power steering
Hey guys , Im having a problem with with my power steering gear box leaking out of the lower seal where the steering arm attaches to the box, I am trying to get the gear box out to replace the seals and I CANNOT get the tire rod (at the steering box arm) knocked loose...I have used a tire rod puller and still no luck is there a certain way to do this...or is there a way to replace the lower seal while its still bolted on the truck??
Old May 21, 2005 | 07:16 PM
KenB's Avatar
KenB
It will come off, just be more stubborn than it is. Sometimes you can grab it with a pulley puller. Heat can be used, but I dislike doing that in those close quarters and possible melting of seals.
Have you marked it and shaft so you can get it back in the same place.
