Pump Swap
Old May 20, 2005 | 09:21 PM
351M's Avatar
351M
Pump Swap
Hey all, I knopw that this will phisically fit but will a 6.9 run with a 7.3 Ip?
Old May 23, 2005 | 08:20 AM
PLC7.3's Avatar
PLC7.3
6.9 and 7.3 share the same pump below certain years check out .......
http://www.mwfi.com/ford_69.htm
http://www.mwfi.com/ford_73.htm
Old May 23, 2005 | 11:04 AM
351M's Avatar
351M
So I could possibly do this as long as the pump isn't turned up? I have 2, one stock rebuild and the other is a turned up one for 7.3s.
Old May 25, 2005 | 11:30 PM
PLC7.3's Avatar
PLC7.3
You can turn up 6.9 and 7.3 pumps but use a pyro with any pump turned up or you could quickly toast your engine......
Check out..... http://www.members.shaw.ca/k2pilot/
Old May 26, 2005 | 01:07 AM
351M's Avatar
351M
I remember this setup, the propane setup is kind of neat. Thanks for the link, I have actually been looking for it. The 7.3 pumps I have are as said, one is a stock rebuild and the other was tuned up by the previous owner of the '90 Ford I have sitting out back.
Old May 26, 2005 | 10:44 AM
Spectramac's Avatar
Spectramac
When we tried this a couple years ago, we couldn't make it run right. It would throw lots of dark smoke. When we tried turning it down it just lost power. Finally had to pull it and put a 6.9 pump back on. Hope you have better luck if you try it.
Old May 26, 2005 | 12:37 PM
351M's Avatar
351M
That just verified what one guy told me at the shop where the rebuilt one was done. (not the guy that we normally deal with) he said there might be differences in the internal pump timing, but do you think I could ever get ahold of the guy that actually knew what the diff would be? LOL.
