Can't Switch Fuel Tanks Properly
Old May 19, 2005 | 10:04 PM
IndieAZ's Avatar
IndieAZ
Hey guys, i'm new here. I have an '89 F-150 Lariat, 5.0 5-speed. I have had a problem ever since i bought it where hte front tank will get to a little below half a tank and the guage stops working (if i switch to the rear tank guage works properly). That was only a nuisance really but i'd like to fix that and i assume it's a bad sender?
But, a new problem has arisen. Last week i filled up both tanks. I was driving on the front tank alone...after about 350 miles running on my front tank i started wondering why it still showed about 3/4 of a tank left. I switched to the REAR tank, and the guage went down to about near empty. So i pulled into a gas station and filled up the rear tank with 15 gallons - so i know the guage was showing accurate, it was definitely empty. So i switched bacmk to the front tank, guage shows 3/4 of a tank...i drove like that for 2 days, switched to the rear tank and its' down to half a tank again??? So it seems like my truck has decided to stop using the front tank, even though the guage will reflect properly when i switched tanks it keeps sucking fuel from the rear. Anyone got any ideas?
Old May 20, 2005 | 07:17 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 20, 2005 | 07:33 AM
F-Liner's Avatar
F-Liner
Indie-
Do a search of on dual fuel tanks. You'll find an abundance of threads discussing your issues.
I too have a truck that only feeds off the rear tank, only mine puts all the return fuel in the front tanks (another fairly common issue). I just haven't taken the time to fix it. I keep a syphon hose to move gas every once in a while. It's not my daily driver, so there are other things that are priorities right now.
