Help With Fuel Filter Change!!!
Old May 19, 2005 | 09:09 PM
ktahelton's Avatar
ktahelton
need alittle help guys ...changed my fuel filter tonite and after I got done you have to crank on the starter alot longer to get it to start, once running it runs great though.opened the water drain hoping to drain the air out but didnt help....thanks Kenny
Old May 19, 2005 | 10:05 PM
vancouverpower's Avatar
vancouverpower
Opening the water drain will drain water/fuel not air. It will add air. Shut the valve and turn the key to "run" about three times for 10 seconds each then try to start it up. That should bleed the air out. Or take the lid off the filter and top it off with fuel or a additive.
Old May 19, 2005 | 10:38 PM
ktahelton's Avatar
ktahelton
hey thanks van Im alittle new to this psd thing . Ill give that a try
Old May 19, 2005 | 10:58 PM
plb7732's Avatar
plb7732
the owners manual says it may run rough for a while until all the air is purged out of the system
Old May 20, 2005 | 12:20 AM
covert_one's Avatar
covert_one
i fill the bowl halfway up with diesel kleen every filter change
