Sponsored by: Auxito
low idle
Old May 19, 2005 | 07:28 PM
Zacr87's Avatar
Zacr87
low idle
hey my truck is a 1998 F-150 with a 5.4 liter engine i was wondering if anyone elses truck idles at 500 RPM because mine does it used to idle at 1000RPM but now it only idles at 500 and i have no idea whats wrong with it i did get exhaust done on it would that have anything to do with it if any of you can help it would be greatly appreciated
Old May 22, 2005 | 08:45 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 23, 2005 | 08:53 AM
berkad's Avatar
berkad
Mine idles around 550 to 600. Always has.
Old May 23, 2005 | 12:50 PM
BillyBob69's Avatar
BillyBob69
Mine is at 500 in gear, 600 in park or neutral.
Old May 23, 2005 | 01:36 PM
furrby's Avatar
furrby
mine at 500 in gear now. it was at 700 in gear. my iac went bad. after i changed it. it moved to 500. you may want to clean your iac and see if that will help.
furrby
Old May 23, 2005 | 03:55 PM
BillyBob69's Avatar
BillyBob69
Furrby has good advice. If after cleaning your IAC the idle acts better, but then returns to being a problem, replace it.
Old May 25, 2005 | 03:33 PM
Zacr87's Avatar
Zacr87
I have a question what is a IAC sorry i don't know all the technical terms (17yrs old and i only do minor mechanical problems)
Old May 25, 2005 | 05:43 PM
triton_2002's Avatar
triton_2002
IAC = idle air control valve
sits on top of the intake, towards the back. Has an electical connector and a couple bolts. The truck usually has starting problems when the IAC is bad. It will start and stall out unless you give it a little gas. However, since you mention that it used to idle at 1k (don't think that's normal) and now its down to 500, it could be the IAC
Old May 25, 2005 | 08:43 PM
NeVeRfInShEd.net's Avatar
NeVeRfInShEd.net
i think this might be the problem with my truck like when im siting at a light it will drop idle and sound like i have a racing cam and everyone thinks its a dragster dont get me wrong it sounds bad *** but is it good for the truck
Old May 26, 2005 | 08:43 AM
BillyBob69's Avatar
BillyBob69
The IAC, (Idle Air Control valve), is located at the top/back of your intake manifold. Two bolts hold it on, and a 2 or 3 wire harness attached to it. Easy to replace. Usually cost about $70.
