shifter
Old May 18, 2005 | 07:40 PM
mav4804's Avatar
mav4804
Question shifter
Hey everyone I have an 1967 F-100 4X4 with and 390 and 4 sped.My ? is how do I get the shifter off to get the manual trans out?
Thanks
Old May 18, 2005 | 08:05 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
If it's a N P 435 a tin cap holds the lever down. Push down against the spring and turn it counter clockwise around 30 degrees then it will release. Don't get me started as there's alot to do to get a 435 into shape after many miles and years use. Good luck.
Carl....=o&o>....
Old May 18, 2005 | 10:20 PM
ceetwarrior's Avatar
ceetwarrior
If it's a T-18 then the cap threads down on it. Then there is a pin that slides out to remove teh shifter, simple stuff. Now to figure out which trans you have as both 4-speeds (T18 & NP435) were common on these trucks.
Old May 18, 2005 | 10:38 PM
jor's Avatar
jor
Reverse is toward the front of the truck on the T-18 and toward the back on the New Process. Anyone have a rebuild manual for the T-18?
jor
