...my front sway bar links, since they hang waaay down below the front axle and threaten to hit every damn rock I go over, are there aftermarket ones available that fix this?
Seems there should be a way to remove them when playing ( do I see a new project in the works?? ) like the jeep boys do. Seems the bar should rotate up out of the way... Now what to do with the links. I'll have to crawl under tonight & have a peek. Several friends with Super Duties, just removed them all together. Gotta be a better way!
Quietman,
Have you decided to shorten the links? Or found shorter ones? Give us an update. I think many of us have the same concern about whacking them on rough terrain. Thanks.
I have yet to find the sorter links I crave.I am heading down to the BoLA friday,and intend on having the problem solved by then, I will post pics on the procedure...
