Sponsored by: Auxito
Tailgate issues
Old May 17, 2005 | 03:26 PM
TJMagoo's Avatar
TJMagoo
Tailgate issues
Ok I thought I was the only one this was happening to, until I tried to open a buddy of mine's F250 Tailgate.
It seems like the handle sticks. You have to push the tailgate in and try to get it to catch and open...or stick the key in and lock it or unlock it to see if that opens it up.
Anyone else have a problem with their tailgates opening??? TIA..
Kel
Old May 17, 2005 | 04:21 PM
Smaug's Avatar
Smaug
With my bedcover on, I have to push it in. If the cover is not on then it works just fine.
Old May 17, 2005 | 07:02 PM
triton_2002's Avatar
triton_2002
The rods that connect the linkage inside the tailgate could be misaligned. Just open the access panel on the inside of the tailgate (its a TORX bolt, forget what size) and adjust the little plastic screw/clamps and that should take care of it.
Old May 17, 2005 | 07:47 PM
fordguy21's Avatar
fordguy21
I have/had that prob, but some good spraying with some spray lube ie silicone, makes a world of difference
spray both latches on the end of the bedliner, spray insode where you insert your key, and take off the access panel and spray any moving parts
Old May 18, 2005 | 07:11 AM
TJMagoo's Avatar
TJMagoo
Thanks for the tips guys. I'll give it a try.
Old May 18, 2005 | 11:18 AM
dennisinmo's Avatar
dennisinmo
I have the same problem. Never know if the tailgate is locked or unlocked because it is so hard to open. I'll try the lube first. Thanks for the help.
Old May 19, 2005 | 10:01 AM
bigdaddyII's Avatar
bigdaddyII
Never had any problem opening or closing my gate. The only thing with it is that the passengers side will unlatch itself. The drivers side holds securly and so does the passenger side until I drive on the highway than when I get where I am going I notice that it is unlatched. So I push it back in till it locks and it unlatches again as soon as I am out on the highway. Tried lubing it numerous times to no avail.
