VIN decoding help & questions
Old May 17, 2005 | 11:53 AM
cdorroh's Avatar
cdorroh
Sorry for the redundancy, but I can't seem to find a decent vin decoder online...
Two potential purchases:
1969 (I believe) F100 4x2, VIN F10YKE73952
1971 F250 4x2, VIN F25HKL84085
Both trucks have automatic 3-speed trannys (does the "K" in the VIN indicate the C6 auto?)
Were the C4 trannys ever used in the early F-series trucks?
Also, does anyone know of a source for factory paint colors?
Thanks.
-Craig
Old May 17, 2005 | 12:02 PM
4Cammer72's Avatar
4Cammer72
c4's were used with the inline 6
Old May 17, 2005 | 03:28 PM
oppy's Avatar
oppy
The F100 (F10 part of the VIN) had a 360 engine when it was built in Kansas City (the "K") in February of '69 (balance of the VIN #).
The F250 had a 390 and was also built in KC in June of '71.
That's all the info you can get from the VIN #. If you want more, check the door tag.
Send me a PM or email and I can point you in the direction of some useful resources.
Old May 17, 2005 | 04:25 PM
cdorroh's Avatar
cdorroh
So if the truck has a 360-V8 and a 3-speed automatic tranny, then the tranny must be a C6?
Old May 17, 2005 | 05:10 PM
Mike G's Avatar
Mike G
Thanks.
-Craig
F10YK is F100 Y=360 FE K=Kansas City
F25HK is F250 H=390 FE K=Kansas City
The FE engine was backed by the Cruise-o-matic in it's early life and then later by the C6 trans, you should have the C6, they did not receive a C4. If you take the color code from your door tag to a local paint shop. they can get you going with a fresh mix.
--Mike
