Here are the results with the latest flash that I have noticed.
The t/h mode is really soft and it will only downshift twice.
One around 50 mph and the second time around 35 mph.
Fuel mileage is improved:
529 miles and used 27.9 gallons. 324 highway miles
205 city miles= 18.96 mpg.
This is the best mpg I have ever had combined driving.
Acceloration is improved, mpg is improved, t/h is wimpy.
If FMC could put the original programming back in the tranny
and keep the engine programming like it is now, we would have
a winning combo. I have no smoke at cold or hot start up,there
is no coolant puking and the engine really idles smooth.
How about if FMC? Will you put the original programming back in
the tranny and leave the engine alone, or is this too much to ask?
EJ
I have found the latest flash on my 03 to be about the same as eharmon except the tow/haul mode... Mine downshifts at slightly higher than indicated speeds and is most similar to when it was new in Feb 03 (although the 2-1 isn't there).
Overall quite pleased with the new flash: Reset the overhead LOM and did a 110 mile roadtrip and the LOM was reading 23.1 avg mpg
I am planning on getting mine done this sat i just hope they can take me. I called them and they said just come on down it takes 20 min no appointment needed. I hope this holds up but either way i need that new flash i have the i think oct and its ok truck runs great but my mpg droped dramatically i used to see 21 on the over head lie o meter now crusing at 70 i see 16 maybe 16.4 at best.. not cool. Getting 430mi out of 29gallons all highway at 70mph...hope the new flash helps this out..
One more thing does anyone know the code for the new flash so i can tell them "the january flash code number ........" they should know though i would think..
Had mine done last week...although the mileage went up a bit and it seemes a bit quieter, I don't like it...the shifting is too soft and it seems like theres more turbo lag...also seems to down shift more often...
The mone/drone I had got 4X as bad after the flash...they then put the new turbo pedestal on and it now sounds like the noise is comming from a closet...still there but muffled...
And, Blackstone just called...6% diesel in the oil...injectors!...
Thanks for the #. I have 35k on the truck right now. hope i dont run into that. Hoping if it was going to fail it would have already..I do about 80-90mi a day all highway only about 2mi each way of trip to work city driving....Hope thigs work out for you
