SuperTech ATF
SuperTech ATF
I did a few searches, and found no history of the stuff.......
First I'd like to ask if anyone has any reason not to use the SuperTech ATF?
I just changed the atf in my new daily driver using the SuperTech fluid. (A very well treated 160k mile car) The fluid was a bit dark and spotty. So I changed the filter, and the quick fluid change (not the TC too). I do plan on again changing the fluid in a few thousand miles.
Is it okay to stick with the Super tech, or should I use something like the DuraBlend ATF?
Thanks
Thanks
