C6 Shift Pattern
Old Mar 27, 2000 | 12:22 PM
vernonharris's Avatar
vernonharris
C6 Shift Pattern
On an 85 F350 4bbl with a C6 tranny:
1) What is the speed that a typical stock C6 tranny shifts from 1st to 2nd, then from 2nd to 3rd?
2) What rpm's is the C6 designed to operate at full load?
3) How do the shift speeds change if the manifold vacuum hose has been disconnected?
4) If manifold vacuum hose has been disconnected, does the kickdown still work?
Thanks,
VH
85 Ford F350 Crew Cab 2x4 351W 4bbl C6
83 Ford F100 2x4 300 2bbl 3spd
81 Ford F350 2x4 400M 2bbl 4spd Dually
Old Mar 27, 2000 | 01:38 PM
mrlaserboy's Avatar
mrlaserboy
C6 Shift Pattern
Dr. Johnson
Nov 14, 2015 08:14 AM
chefcharles
Dec 9, 2014 12:11 PM
David Moran
20
Nov 7, 2014 11:06 AM
MoonpieH2O
Sep 28, 2012 09:04 PM
ford4ever_2003
Jan 20, 2012 08:04 PM
