Cps Pre-planning
Old May 16, 2005 | 04:24 PM
bug juice's Avatar
bug juice
Cps Pre-planning
OK, just doing some pre-planing maintenance...
The bolt to remove the CPS is also holding a timing pointer in place...right? That is the one I've loosened and put a little anti-seize on for the future...
I have read alot here about replacing the CPS and alot say to pull the #9 C/B under the hood, my '01 manual says that is "10A Left headlamp (low beam)" is this right or should I be looking for something else? I sure would like to know which C/B to look for if this one is not right as disconnecting both batteries on the road may not be feasible....
