Sponsored by: Real Truck
Keyless Entry FOB Problems
Old May 16, 2005 | 12:12 PM
fn250's Avatar
fn250
I dropped my keys yesterday, and just my luck they landed right on the Keyless Entry FOB. For a couple of minutes my FOB wouldn't work at all. Now it works but I have to press the button a couple of times. I've seen new FOBs on Ebay, can I just order the new FOB and program it to my truck, or does a dealer have to do this? I don't even wanna ask the dealer about it until I get some info from a 3rd party.
Thanks,
--Juan
Old May 16, 2005 | 12:54 PM
HeavyAssault's Avatar
HeavyAssault
If you read through your owner's manual, you will find the procedure to set the FOB to your truck.
Buy one off EBAY, and set it yourself.
Old May 16, 2005 | 01:12 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Sounds like the battery is getting weak.
Just like a flashlight that gets weak, you hit it, it works. The batteries get weak and any resistance at the connections makes the light dim. You bang it, the batteries contact better and it works fine for a little while, then goes out again.
Change the battery first - if it's not the battery, get a new fob and keep the spare battery.
Old May 16, 2005 | 05:03 PM
fn250's Avatar
fn250
thanks guys
Old May 16, 2005 | 07:06 PM
97F250XLT's Avatar
97F250XLT
keyless fobs
I just traded in my old 97 250 with the keyless entry fobs and had used them lots and original batteries. The same with the truck. Check that some dirt is not holding the switch so it will not work. A very handy option I did not want on my old truck but ordered on my new one. Good luck.
Old May 17, 2005 | 11:09 AM
Big's Avatar
Big
One more thing to try is to make sure the battery is making contact. I have run into that before where the contacts to quite hit the battery. You should be able to bend those to ensure a good contact.
Might save you from buying a battery.
Big
Old May 17, 2005 | 11:49 AM
rlh68050's Avatar
rlh68050
If you need a new key fob, send me an e-mail and I will get you one for the price of postage and a few dollars. I have lots of them (don't ask)
rlh6805@wideopenwest.com
