Fuel Tank Install Problems
Old May 16, 2005 | 11:28 AM
oldfords4ever's Avatar
oldfords4ever
I need help for anyone that moved the gas tank from the cab to between the frame rails.
I installed the tank this past weekend and found two problems, one being the gas gauge is reading full all the time. I am using a 22 gallon tank from a mustang with the stock gauge in my '64 250. It is the stock gauge the problem or something else. On the sending unit there is no post for a ground would this be the problem.
The second problem is the seal around the sending unit is leaking what is the best fix for this as well?
Any help would be great.
Andy
Old May 25, 2005 | 02:45 PM
dendyr's Avatar
dendyr
It sounds like you need to ground the sending unit. As far as the leak goes, go do and get a replacement gasket from your local auto parts store.
