help with 96 psd
Old May 15, 2005 | 09:09 PM
kens crewcab's Avatar
kens crewcab
help with 96 psd
i need help, my truck a 1996 crew cab 4x4 psd, the idle gos up and down by 2 to 400 rpm , and some times heisatates when pulling out, and a flat spot when crusing, no codes new fuel filter just cleaned the air filter any help!
Old May 16, 2005 | 09:13 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
How many miles on the oil?
Old May 16, 2005 | 09:20 PM
kens crewcab
3800 miles on oil and filter
Old May 16, 2005 | 09:29 PM
cookie88's Avatar
cookie88
FTE Emeritus
Might be as simple as an oil change.
Old May 17, 2005 | 08:02 PM
kens crewcab
on a scanner the hpop is going up down 400 lbs is this normal, what should it be
Old May 17, 2005 | 09:03 PM
cookie88's Avatar
cookie88
FTE Emeritus
Nope, not normal. It might still be an oil problem, but it's likely your injection control pressure sensor, or the injection pressure regulator has a problem.
I would still change the oil first.
