Unidentified Sensors
Old Apr 1, 2000 | 06:55 PM
Pastmaster's Avatar
Pastmaster
hi guys, I did an oil change and replaced the pvc plug today, I did some investigating. I found to sensors that I don't know what do.
The first one is a small one at the front of the drivers site intake manifold, it looks to be a vacuum link. Any one know what it is or what it does?
The second one is between the 5th and 6th cylinders also one the lower intake. Thanks for the help
Evan A.K.A. PastMaster
1993 F-150 302/E40d XLT
1989 F-150 302/Aod 4x4 XLT Lariat
Old Apr 1, 2000 | 11:35 PM
PAUL_2's Avatar
PAUL_2
Evan ,
I think what you are looking at is a vacuum tree ..its just a central fitting for various vacuum lines and the sensor Im guessing is the Air Charge Temperature Sensor ? Does it screw in the intake or the block ? If it screws in the block its most likely the Coolant Temp Sensor .
Paul
Old Apr 2, 2000 | 04:22 PM
Pastmaster's Avatar
Pastmaster
Paul, IT may be the charge sensor, it is in the intake, its not the The coolant sensor, it is underneath the distributor,
Old Apr 2, 2000 | 09:45 PM
PAUL_2's Avatar
PAUL_2
