Western Nationals June 25th - Grand Prize Drawing - 5.8L/351 crate motor.
Winner not be present - Ford will drop ship to your house.
8.5:1 compression ratio
Ford racing dual plane 4V aluminum intake, Ford Racing tall polished aluminum valve covers, V-belt standard rotation mid 70's style cast iron water pump with left hand inlet, aluminum timing chain cover with fuel pump mount, fuel pump block off and eccentric, E5AE-6090-CA cylinder heads without thermactor air passages, F4TR-6380-AA HD truck manual trans flywheel, high torque flat tappet cam E7JE-6250-AA, full sump oil pan, Duraspark distributor and coil, spark plug wires, block is hydraulic roller cam compatible.
<!-- / message --><!-- sig -->
Pickups limited grand prize is a crate motor. $1 a ticket.
Make the check out to "pickups limited" Or use Pay Pal using my email address
oehome at verizon dot net
Please include your phone number for the ticket stubs. I'll mail you back
the tickets.
