Engine Swap
Old Mar 10, 2000 | 05:19 PM
micah's Avatar
micah
Engine Swap
Old Apr 3, 2000 | 03:06 AM
Mattco26's Avatar
Mattco26
Engine Swap
Alright, I have an 89 F150 4x4 with a 302 and aod. The motor looses oil pressure once warmed up, and the engine has developed a knock now. When I got it I replaced the pump and added a mechanical gauge, but I still got the same results. The question is, I found a great deal on a used engine from a neighbor of mine. Its a 302 and it came from a 94 f150 4x4 with od tranny. Now do I have to do anything other than switch the ground on the injectors because of the different firing order? Will all the accessories bolt up. Its almost a complete engine, it has all the FI stuff on it, Ill need to use my alternator, etc. Could someone post here and also email me asap, I dont want to loose the engine, If I act fast I can get it for cheap. My email is Mattco26(No Email Addresses In Posts!) thanks in advance
Old Apr 3, 2000 | 09:22 AM
slikness's Avatar
slikness
Engine Swap
Everything should swap great. I don't know about the firing order situation. But the front accessories should swap old to new with no problems.
'82 F150 2WD w/351W (orig 300 I6)
Slik
