Bronco II Ford Bronco II
when in doubt ask an expert
Old May 15, 2005 | 12:50 PM
phoenixjmw's Avatar
phoenixjmw
I have been going through your forum for a couple hours and you guys really seem to know your stuff. Hopefully you can help me in the right direction. 88 bronco 2, 2.9efi, auto, 120,000 miles, from nys. Bronco2 has an ever decreesing range of drivability. Starts now to lose engine power after about 4 miles. It doesnt stall much but just sort of dies out unless you give it a little gas, then it kicks in and goes for 20 seconds then dies out again. If I let it sit for a while it runs fine again. I get the black smoke others mentioned and MPG drops to about 1 mpg. However it doesnt usually stall and will always start. I am doubting fuel system problem just because of the fuel efficiency drop. It acts a lot like a bad cap but that and wires and coil was replaced. I had a similar problem that was resolved by replacing Alt and Bat. Could a defective Alt/Bat cause this even though they are new and passed a check at autozone? Would you agree it sounds electrical? suggestions?
Old May 15, 2005 | 01:19 PM
phoenixjmw's Avatar
phoenixjmw
I read a thread similar to my problem but it was a different vehical. Does an 88 bronco 2 have an fpr and how can I check it?
Old May 15, 2005 | 07:23 PM
Ken00's Avatar
Ken00
I would start by pulling the codes (see the link on pulling eec-iv codes in the tech info thread at the top of this forum), testing the fuel pressure and checking for a bad FPR. The FPR is on the drives fuel rail, run the truck for a few minutes, shut it down, pull the vacuum line and check for gas, gas=bad.
1badcj8
Feb 24, 2013 02:06 PM
po3bowers
Feb 14, 2013 09:13 AM
WH 6.0
Nov 16, 2011 01:39 PM
phoenixjmw
Bronco II
18
Jul 15, 2005 02:21 PM
