Sponsored by: Kumho
Rust; When to worry?
Old May 14, 2005 | 08:03 PM
OneBang's Avatar
OneBang
Question Rust; When to worry?
I was crawling around under my '89 150 (279,xxx miles) today, doing a bit of exhaust maintenance. I noticed I was flaking off a lot of rust from various points on the frame and suspension components. Does anyone have an idea as to when I should start to worry about too much metal being lost? The rear leaf spring mounts are the main area I'm thinking about.
Old Jul 17, 2005 | 12:15 PM
Franken-Truck's Avatar
Franken-Truck
Sorry it took so long for someone to answer, I just happened upon this thread in a search. Surface rust, and minor pitting, I wouldn't sweat just yet, but if you have flkes coming off, your losing a lot of metal fast. I'd have to see the frame in question to guage what kind of hazard it may pose. I would get under there and start chipping away all the flakes that you possibly can, and heavily treat the frame in that area with a chemical rust converter such as Ospho. Then paint with a good industrial rust preventing paint. It may not cure the rust completely, but it will slow it down for sure
P.S. What size flakes are we talking? The areas I patched on my '78 had silver dollar sized, 1/4" thick chunks coming out
Old Jul 17, 2005 | 05:22 PM
FSC's Avatar
FSC
I think if it gets to where there are holes through the metal, however small, its time to worry.
you can remove the loose rust, prep and paint, but IMHO, it's a losing game.
I have an 87 f150 that has no frame past the rear axle, anyone know where I can get a cab back frame section?
