Sponsored by: Kumho
changing or flushing power steering fluid
Old May 14, 2005 | 03:05 PM
seizure911's Avatar
seizure911
Any one ever change or flush their power steering fluid?
Can it be done without removing a lot of parts?
my truck: 1993 f250
Old May 16, 2005 | 05:41 AM
SRD4X4's Avatar
SRD4X4
Remove the return line from the pump and stick it in a jug/drain pan.Plug the pump where the line was attached and fill the pump.Start the truck and let it idle while you keep adding fluid to the pump until the fluid coming out is clean.Don't let the pump run "dry" though,get someone to help you so you can shut the engine down before the pump runs dry.
