Hot or Cold, No Warm
Old May 14, 2005 | 10:41 AM
'70-4xFord's Avatar
'70-4xFord
Question Hot or Cold, No Warm
I've a '99 F-150 and the temp control usually will not come off of hot. There are a times when I can get it to blow cold air, but if I let the rpms drop below idle speed or if I hit a bump or no reason, I hear the blend door shut (or open) and the hot air comes rolling in. I have to turn the heat/A/C switch to the off possition and leave it off for a while before I will even have a chance a reclaiming cool air again. Anybody have any ideas on whats wrong or how to fix it?
Old May 18, 2005 | 03:23 PM
jtmerritt's Avatar
jtmerritt
Sounds like possibly a vacuum problem. Check all vacuum lines under the hood and under the dash for a possible leak.
John
