blank heating controls on 05
Old May 14, 2005 | 07:00 AM
nanuke1's Avatar
nanuke1
My heating controls go totally blank and inoperable about once a month and lasts for about 24 hours. Anyone else have this problem
Old May 14, 2005 | 02:29 PM
Forest's Avatar
Forest
I assume you mean automatic climate control screen below the radio? Mine does the same thing. Comes back after truck has been off for > 5 minutes.
Old Nov 6, 2005 | 10:34 PM
Downsized2X's Avatar
Downsized2X
Diesel User
'04 PSD X, same issue
My climate control screen went blank today. I remember reading about this phenomenon and was planning on replacing the fuse and/or doing a search on FTE to see what was up. I found the fuse value while at one of those three-minute lights. I also tried all the other circuits to see if it was more than the climate control. Nope, that is all it was. I was about a block from home (20 minute ride total) and was wondering if it was only the backlight that was out, so I tried hitting the fan and temp control several times on the steering controls. All of a sudden, I heard a relay click and all is well. I never had a chance to turn off the ignition because I was still en-route. Is this problem caused by a sticky relay or is there more to this? Now that this happened, am I going to see this again?
Old Nov 7, 2005 | 02:35 PM
ZBeeble's Avatar
ZBeeble
I had mine (2004) go dead twice. I had the dealer replace the head unit and it hasn't happened since.
Old Nov 7, 2005 | 10:48 PM
bmenzel's Avatar
bmenzel
My 2005 diesel Ltd climate control panel went blank right after starting engine. Waited a couple of seconds pushed climate control buttons, nothing. Rotated the light switch and and voila. Panel lit up and no problem since...
Old Nov 8, 2005 | 09:51 AM
quietman's Avatar
quietman
Mine has gone blank AND the A/C etc stopped working several times this summer. Starts working again in a few minutes. I am assuming it is a breaker that trips and then resets.
_____________________
Quietman
www.roenation.com
2005 EXCURSION LIMITED Eddie Bauer edition 4X4 PSD
4" FabTech lift/level, Bilstein mono-gas shocks, Rancho Steering Stabilizer
Silverstars, BFG 295/75/16 AT KO's on Factory Mags
LANDYOT Generation II Radius Rods, Ford factory hood insulator
