NooB
Old May 14, 2005 | 12:55 AM
minipigg's Avatar
minipigg
NooB
Ok.. Im a total noob here. Last week I came across an 1985 F250 2X4 with the 6.9 diesel. 500 bucks and its mine if I want it. I have owned other diesels before some Im not totally in the woods. But I know absolutely nothing about the 6.9. I am still trying to do some searches and get more information. I do how ever have some Q's I'd like to ask if thats ok.
1) What kinda fuel economy do these get? I intend on either converting this truck over to a 4x4 or using the engine in another truck.
2) What common issues do they have? Are they lemons?
3) Weight.. I have another rig with a straight six gasser in it that I might convert to diesel. Is the 6.9 as heavy as a cummins L6?
Im looking at a Cummins 4BT too... but its a couple grand more. One of my buddies convert his 4x4 to the 4BT.. he gets 15-19mpg city and up to 27mpg highway running 33x12.50's 4.10 gears and standard transmission.
Old May 14, 2005 | 07:46 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old May 14, 2005 | 03:55 PM
nogo73's Avatar
nogo73
1) every truck is different hard to say but a guess would be 10-20mpg
2) head gaskets , glow plugs , burning oil(alittle bit), and if you have an older 6.9 don't use the block heater it could crack the block. I'd say its nowhere near a lemon.
3) a complete drop in 6.9 wieghts around 1000lbs
that 4 cylinder is not far off from being half the size of the 6.9 plus the 6.9 a N/A and not designed to handle alot of boost with its high compression of 22.5 to 1. unless you put an intercooler on it going over 12psi doesn't do anything(or somthing else to cool down the charge).
