aftermarket servos
Old May 13, 2005 | 10:46 AM
ford_nut's Avatar
ford_nut
aftermarket servos
guys
Does anyone have any experience installing Aftermarket servos in a C6 tranny? I am not talking about a shift kit; I am talking about swapping out the servo assembly to increase band apply force. Is it worth the investment?? Here is a description of what I am talking about (this was taken off of summit racing online):
JET Billet Powr-ServosHarder, stronger shifts.
For heavy towing or high performance applications, use JET's Billet Powr-Servos. They install easily on the outside of the transmission housing and features a large apply area, which holds the band with greater force. They improve the 1-2 shift and prevent band slippage under hard throttle or towing conditions.
Old May 13, 2005 | 01:09 PM
thesprocket26's Avatar
thesprocket26
Do you want a "comfort" ride or a "race" ride. You shifts will be almost instant. NO shift lag. This will chirp the tires and hurt your back if your motor has enough power.
Old May 13, 2005 | 01:46 PM
ford_nut's Avatar
ford_nut
Hi
I would be putting the servos in a C6 with stock 360
chirp tires huh? In a 72 F250 2wd? nah, I find this hard to believe!
Old May 13, 2005 | 11:53 PM
thesprocket26
Ha ha ha. stock 360 = not enough power. Try 350+ hp. I think you have 127hp or so.
Old May 14, 2005 | 03:24 AM
"Beemer Nut"'s Avatar
"Beemer Nut"
Also change the servo arm inside to get a higher mechanical advantage. If you can find the relineable forged intermediate band it's alot stronger but hard to find.
Carl....=o&o>....
