decoding tire size
Old May 13, 2005 | 09:01 AM
fordxxx's Avatar
fordxxx
decoding tire size
I am sure some of you understand what the numbers that designate a tire size mean. For example P215/75R15...what does each number mean.
Thanks
Old May 13, 2005 | 10:15 AM
bsour's Avatar
bsour
http://www.tirerack.com/tires/tirete....jsp?techid=46
Old May 13, 2005 | 10:18 AM
qman's Avatar
qman
P -passenger tire (I think)
215 - width of the tire tread is 215mm
75 - height of the tire is 75% the tread width (75% of 215mm = 161.25mm)
R - Radial
15 - the diameter of the rim it was made for is 15"
After I typed all that, I found this:
http://www.discounttire.com/dtcs/infoSidewall.dos
Old May 13, 2005 | 10:19 AM
bsour's Avatar
bsour
That link won't work properly. You will have to copy, paste, and edit:
www(.)tirerack.com/tires/tiretech/techpage.jsp?techid=46
Old May 13, 2005 | 10:22 AM
qman's Avatar
qman
bsour, I guess we were responding at the same time. The tirerack website has better detailed info than does Discount's.
Old May 13, 2005 | 04:50 PM
fordxxx's Avatar
fordxxx
Thanks guys. So if I wanted a tire that was wider but about the same diameter (so I wouldn't have to change my speedo gear) then I could replace my P215/75R15's with P230/70R15's. Does that sound right?
Old May 13, 2005 | 04:54 PM
qman's Avatar
qman
Calculates out to be the same.
Old May 13, 2005 | 07:49 PM
bfgfocus's Avatar
bfgfocus
I am not sure if you had a typo, but it should be "235/70-15"
